Salutare,
Dupa ceva vreme de liniste, revin cu un exemplar care imi place foarte mult.
Am incercat mai bine de 6 luni sa stau departe de acest microb - ceasurile.
Acest model a trezit in mine iarasi pasiunea de a-l avea. Este de o simplitate enervanta.
FLIEGERWATCH with the ledendary Unitas 6498 handwinding movement
A reduced design in a perfect finished case, sapphire crystals and a very nice and high decorated movement. Like the Original STOWA airmanwatch from the fourties. Made In Germany. Since 1927.
casesize: 41 mm
crystal: sapphire crystal - inside Ar (AntiReflection) coated
strap: 22 mm
movement: handwinding Unitas 6498 with blued screws, code de geneva, golden STOWA engraving
caseengraving: FL 23383
(like it is on the Original big STOWA Airmanwatch)
Temperature blued steel hands with Superluminova C3 filling
without second hand (like Panerai Referenz 372)
solid caseback is available with additional costs (Euro 90.-)
Do you want to have a individualized watch? Please click here to go to our Onlinedesigner where you can draw and individualize parts of your watch. Try it, it is very easy!
