Nici rusii nu se lasa mai prejos , fac si ei modele uriase.
Sper sa va placa acest Poljot-Pilot chrono , model 2009.
diametrul fara butoane : 45 mm
diametrul cu butoane : 56 mm
grosime : 15 mm
grosime : 15 mm
ce stiti despre aceasta marca de ceasuri daneza :
Skagen 759LGL
origine : Danemarca
colectia: Clasic
mecanism automatic cu 21 de rubine
carcasa din otel
placat aur 18 k
curea din piele
geam din cristal mineral usor bombat
data
repere si indicatoare fosforescente
diametru : 38 mm
grosime : 12 mm
greutate : 68 gr.
rezistenta la apa : 3 bari
ma interesa in special daca folosesc mecanisme in house ??
http://www.ceasuri-tempora.ro/show.php?id=724
Skagen 759LGL
origine : Danemarca
colectia: Clasic
carcasa din otel
placat aur 18 k
curea din piele
data
diametru : 38 mm
grosime : 12 mm
greutate : 68 gr.
Nu folosesc mecanisme in House.
Sunt Miyota.
Sunt Miyota.
si cum este mecanismul myota pe langa seiko 7s26b?
Comparabile.
Singurul dezavantaj care-l gasesc la Miyota este faptul ca are armare unidirectionala,si trebuie purtat mai mult-sau mai activ.
Salut si La multi ani!
Am citit de curand despre mecanismul in-house al celor de Carl F. Bucherer, denumit CFB A1000.
Specificatiile tehnice descrise de producator:
"Specifications of the CFB A1000 caliber:
Mechanical automatic movement wound by a bidirectional rotor running around its edge.
– Diameter: 13 or 30 mm
– Height: 4.30 mm
– Functional jewels: 29
– Frequency: 21,600 beats per hour,3 Hz
– Power reserve: approx. 55 hours
– Escapement: Swiss club-tooth lever escapement
– Subassembly: Nivarox Type ASUAG No. 8
– Balance: ring-shaped, gold-plated Glucydur beryllium alloy balance
– Double roller: nickel-plated brass
– Impulse pin: jewel, red
– Balance spring: flat (volute), CGS 71, Anachron,
thermally treated Etastable
– Collet: Greiner
– Escape wheel: steel, polished flat, 1 chamfer,
polished impulse face, epilame-coated
– Pallet: steel, polished flat, fork notch rounded off
– Pallet stones: red, synthetic ruby, epilame-coated
– Impulse angle: 50
– Index: classical"
Ce parere aveti?
Cu stima!
– Height: 4.30 mm
– Collet: Greiner
– Impulse angle: 50
– Index: classical"
Ce parere aveti?
Cu stima!
Superb mecnism!Foarte compact si robust ...
Interesanta solutia pentru armarea automata!
Foarte tare aceasta solutie dar nu este noua
Am prezentat ceva "asemanator" din colectia mea aici http://www.ceasornicar.ro/forum/viewtop ... =13&t=6947
si aici Longines http://www.ceasornicar.ro/forum/viewtop ... a&start=15
Este o veste buna ca cei de la Bucherer au ales aceasta solutie .
Sper ca lumea mecanismelor in house va creste in ciuda crizei.
Mecanismul de armare o sa fie mult mai rezistent la shocuri mecanice...
Stiu Lucian ca nu este noua,interesanta este alegerea acestui tip deoarece a fost abandonat o buna perioada de timp.De aceea este interesanta intoarcerea la "radacini"!
Eu nu pot decat sa ma bucur ca a revenit cineva(si nu oricine) asupra acestei solutii originale.
Imagini ati vazut cu acest nou mecanism?
